Subaru b4
richie250, May 12, 5:06pm
I have a rsk subaru b4 108000kms has started making wineing sound in front. Could this be the front diff! gearbox still nice and tight.
-90-, May 12, 5:31pm
Alternator bearing
miniclubmangt, May 12, 5:40pm
Could be turbo whine! Coulod be anything to be honest
franc123, May 12, 5:42pm
Too hard to say without knowing whether its engine speed or load related, or road speed related.
richie250, May 12, 6:35pm
not turbos . turned engine off down hill and whine was still there.
-90-, May 12, 7:42pm
^ missus in the passanger seat !
hijacka, May 12, 8:20pm
Wheel bearing.
suplyuparts, May 12, 10:13pm
sounds like front diff.
ralphdog1, May 13, 6:39am
So road speed related and does not matter if the power is on or off!
hijacka, May 13, 6:58am
Lift the car up on hoist or 4 axle stands so all wheels off the ground. And start engine select gear and look at all the wheels spinning, if 1 or 2 are slower or hesitant then bearing or hub is your problem. usually the left front due to curbing
richie250, May 13, 3:01pm
Yer makes no differenceif engine is on or off cheers
richie250, May 13, 3:03pm
It just went through testing station warrent could they of missed it if it was a wheel bearing!
hijacka, May 13, 4:20pm
Yes,they only check play
kaituna, May 13, 4:38pm
Cat stuck on the cross member!
trogedon, May 13, 5:26pm
Mother n law!!
outbidyou2, May 13, 7:36pm
clubsub.org.nz - be more specific and these guys will help you
