Have a legacy b4 2001 twin turbo manual. Cuts out at 100km when going up hill, and stutters abit when going up hill - seems to drive fine on the flat though. Have tried replacing the AFM and no luck. Anything else I should look at! Thanks in advance
Apr 5, 6:40pm
yea what fuel are you using on that! shell by chance and 91 octane!
bubbles244,
Apr 5, 7:09pm
what you have described sounds like fuel starvation .
prt21,
Apr 5, 7:22pm
using 95 fuel, sometimes shell.
hijacka,
Apr 5, 8:33pm
You really should give it a diagnostic test first, As a guess #3 could be right, have you had this problem with a full tank of fuel! The problem with replacing the fuel pumps on the be/bh models is that Replacement walbro fuel pumps and others hit the bottom of the tank and neither a gss341 or 342 is the right replacement, should be looking for a 340 but don't bother you can't get them. You can run a 341 or 342 but not even the small 90'' bag clears it and either pump will only fit without the bag which leads to fuel starvation.
alltorque350,
Apr 6, 1:59pm
When did you last change the spark plugs!
