89 Commodore won't go?
b0tts, Apr 4, 5:54am
this is my own doing but was stripping the car out for a demolition derby thats coming up pulled the dash out and now the car won't start any sugestions!
pollymay, Apr 4, 6:40am
Trick question, those things never run :P
You can put the dash back in! Just run the cluster and nothing else, tape it to the pillar or something. Otherwise you can check fuses, is the fuel pump kicking in, are the injectors firing and do you have spark!
motorboy2011, Apr 4, 7:12am
cars are stupid like this, if i unplug my speedo/rev cluster in my stagea the battery doesnt charge!
bigfatmat1, Apr 4, 7:17am
That's because it uses the warning light current to excite the alternator.
op have you unpluged the key reader and or bodycontrol module if a vn
b0tts, Apr 4, 7:50am
The car runs fine put the dash back in only got battery light and cbs light going still not any ignition i guess ive missed something somewere
male_timaru, Apr 4, 7:59am
Take it slowly - go from negative and positive posts from battery to dashboard lol
May take a while but you will notice if wires not attached or missing from vital components .
tonyrockyhorror, Apr 4, 10:08am
Can't you just put up some alternator porn in the engine bay!
tonyrockyhorror, Apr 4, 10:27am
