1998 hilux electrical fault, Batt light on all the time when running, no other dash lights working, Head lights break lights working, hazards working but not indicators! Thank you for any ideas or help you have=)
andy61,
May 19, 1:14pm
It will be the break lights at fault.Fix them breaks
bigfatmat1,
May 19, 1:17pm
a faulty alternator maybe
May 19, 2:03pm
1. Check alternator belt is there and tight. 2. Check your fuses and fusible links. 3. Check that your battery terminals are tight, incuding the earth that goes from the negative to the body. 4. Check the charge rate between battery terminals using a multimeter. It should charge at around 14V.
josephbudd,
May 19, 2:23pm
thanks will do that now, fingers crossed
josephbudd,
May 19, 3:45pm
1 2 and 3 have not helped and I don't have a multimeter, I had just replaced the front indicator lights so that must have caused but not sure how.
jmma,
May 19, 3:52pm
Are they identical to the ones you replaced This was a very important piece of info you left out. Anything else you changed or fitted!
josephbudd,
May 19, 7:35pm
The new ones are LED replacing the bulb originals, We might be on to something jmma
jmma,
May 19, 8:19pm
Sounds like something is not quite right with the new ones, maybe wiring is different.
