Toyota Hilux Clutch?
danski6, May 20, 6:16am
Does anyone know how to establish which thrust bearing to use! I believe toyota uses three different size (thickness) bearings. I am matching a LN106 bellhousing to a 3L engine, have the short fork. Any advise much appreciated.
gadgit3, May 20, 6:21am
There is only one for the 106. If your buying the genuine kit it will have the correct one in it. If your going after market then you will have to match up to what the supplier has in stock. If you put the bearing face down and measure from the table surface to the tag on the bearing housing you will have the spec you need
danski6, May 20, 7:08am
Thanks, just unsure how far forward the bearing would normally slideon the g/b input housing. I assume it would'nt slide forward beyond the end. My new pressure plate and bearing are not from a kit unfortunately.
