Cause of car heater burning feeling in throat?
bellasmoons, May 31, 6:58pm
I just drove home and had the heater going. Changed the heater so itwas coming out directly infront and next thing it was like if you imagine opening an oven door when you have burnt food in it but without the visible smoke. Had to turn it off and choked, tears in my eyes, my throat is still in pain now. What the hell happened!
bellasmoons, May 31, 6:59pm
It's that subaru impreza you guys told me not to get lol ^^ Been a pretty reliable car other than this tonight.
morrisman1, May 31, 7:07pm
air conditioned!
daryl14, Jun 1, 6:34am
Someone's put some nasty shit in the vents. Get it checked out.
kazbanz, Jun 1, 6:43am
my thinking is a smell neutraliser is in there and the heat is causing a weird effect
edangus, Jun 1, 6:56am
Boiling Battery! Had this on an Accord. New battery fixed it.
saxman99, Jun 1, 8:00am
Could this be a little bit of vapourised coolant!
usdefault, Jun 1, 9:54am
Change the cabin filter.
noswalg, Jun 1, 3:31pm
Definitely something to look at, I've had a subaru heater core go before and it smelt pretty bad. usually would see some steaming of windows though or a wet floor under dash if really bad
bellasmoons, Jun 1, 8:13pm
I will show husband these comments and tell him to test drive the car and see if it does it again. Im not going to try again to see if it happens twice -- not fun + not good being preggers. ^^
intrade, Jun 1, 8:42pm
get it checked it can only be 2 things either its got a crack and is eveporarting coolant glycol that would cause a burning . or its got a airconditioning leak, i dont know if that gas is causing problems and or how toxic it would be but coolant cuases iritatin and has a destinctive ugly smell sweet smell
intrade, Jun 1, 8:43pm
only other thing causing irritation would be burning wiring
cpnnz, Jun 1, 9:20pm
could be oil leaking from rocker cover gaskets burning on exhausts, then the fumes from that being drawn through the heating, and out the vent into your face. have struck it many times on Subarus.
