Car door lock swap
kim-rob01, Jul 3, 8:00am
my drivers side door lock wont open properly with the key can i swap passenger side lock with it or is it more complicated than that,,cheers for any info,,,
barbuzz, Jul 3, 8:21am
It's more complicated. the rods for the lock will be around the opposite way. Maybe try fine a 2nd hand lock & get a locksmith to match it to your key.
rob_man, Jul 3, 8:31am
They are interchangeable on most cars, you need to take the little arm off the back of the lock and turn it 180 degrees to make a mirror image.
kim-rob01, Jul 3, 9:11am
thanks guys ill give it a crack jus didnt want to be wasting my time for nothing cheers
jasongroves, Jul 3, 9:13am
If you are going to the trouble of removing the lock, you may as well take it to a locksmith to get repaired.
Its not very expensive;)
kim-rob01, Jul 3, 1:01pm
its a corolla 92 about to have a crack now cheers
lookoutas, Aug 22, 10:11pm
They could also be ACDC
