have a bit of a problem with the radiator water in my 1996 daewoo espero.the car has a pressurised system,no radiator cap just a large container on the bulkhead.no sign of a leak anywere,no sign of water in the engine oil,car has never overheated,No4 spark plug shows signs of rust keep the container full and the car runs and starts beautifully .car has only done a genuine 137000 kms from new.any help would be appreceated
gofer0007,
Jul 3, 2:29pm
has It got a header tank with a screw cap!
tadpole7,
Jul 3, 6:26pm
yes it has but there is no sign of water getting out of it.
jono2912,
Jul 3, 9:02pm
Top or bottom of sparkplug!
bowla3,
Jul 3, 9:10pm
Suggest a leak in the header tank area. Had a similar problem with a Surf. Put a new radiator cap on. No more loss of coolant. Pressurised system, coolant in radiator expands when hot, goes into header tank. Tank overflows, pushing coolant onto road.When cooling down, coolant should be sucked back to radiator. If a slight leak in system, no suction, coolant does not return. Think you should have it checked by radiator specialists.
big.b-lil.c,
Jul 3, 9:58pm
is the carpet in the car wet! it maybe the heater leaking
phlippy,
Jul 3, 10:13pm
lol i have a xg ford pano the last month i turned the heater on to the feet setting and got soaked with a huge waterfall havent used it since so i guess i better get that checked. thought it was maybe rain water got in somewhere
ceebee2,
Aug 26, 9:04am
Bump for Jono as this question will reveal all!
