hi the utes decided to make me walk , i noticed theeletric fuel pump was making a little bit of a different sound ,got half way home ,the old girl stopped ,ive checked the fuses ,all ok ,do they have a reset ,or am i up for a newy ,, any help would be great ,cheers tony
jash3,
May 28, 6:52am
I didnt know they were eletric.arent they manual pumps!
lukey22,
May 28, 6:57am
no shes humming behind the passenger seat
lukey22,
May 28, 6:58am
fuel injected
v8_mopar,
May 28, 6:58am
Normally they get noisy when there's no petrol going through them
v8_mopar,
May 28, 7:07am
You could have a block before it or the fuel gauge could be wrong and you have a gas maybe
lukey22,
May 28, 7:31am
gauges on quter and accurate normally .shes makin no noise usully humms all the time,just stopped thenso did i, every thing else fine power to fuse ect
lukey22,
May 28, 7:32am
ill check for a block tho.
supernova2,
May 28, 7:35am
Hook up the pump with some jumper leads and see if it runs then - that will eliminate any wiring issues.
