had been driving fine, then the other morning i was driving it and it was very gutless, on flat road will have foot flat going 100km at 3500rpm, when i ease on the foot and let it go to fourth gear it will decrease in speed and the rpm will go up again.Last night i took it for a drive and it was driving fine again, this morning drove it about 10km, stopped and went to go again and it was back to being gutless, any ideas what the problem could be! 2.7TD 1996 terrano auto. 202000km.
chutneyman,
May 21, 5:10pm
!Air Flow Meter
May 21, 5:11pm
I would start by check the air intake hose for splits, between the air flow meter and turbo charger.
The next thing I'd check would be the brakes. Make sure they are not stuck on.
rob_man,
May 21, 5:43pm
Sounds like it's auto. Maybe the trans is slipping if the revs are all over the place, check ATF!
serendipitous6,
May 21, 6:04pm
its underpowered in all gears.
magwarehouse1,
May 22, 4:54pm
change your diesel filter and air filter
unclejake,
May 22, 4:58pm
Do the 2.7TD engines have EGR!
unclejake,
May 22, 5:08pm
Errm, the tumbs down icon suggests what!
That it was a stupid question or that the EGR could be the culprit!
May 22, 5:28pm
The icon means "unfortunately so".
And, yes, it could be a culprit. Definitely not a stupid question.
4piggy,
May 24, 6:51pm
its common for them to have internal inj pump faults which can be intermitent may pay to have it scanned
