Hi there just wondering if anyone knows how to remove tail lights out of 1994 hilux surf ssr v. have taken 2 screws out of side is there onother 2 on inside!
Jun 12, 4:00pm
From memory, the tail light is clipped in on the outer edge.
grangies,
Jun 12, 4:38pm
Once the out side screws are off. Grab the whole lens with both hands wrapped around the 90' degree angle where it goes inside the tailgate jamb, and give it a good wriggle. Up down , left and right.
Basically shake it out.
I'm pretty sure they're held in by lugs that are pushed into the body. They are strong so don't be scared to use a bit of vigorous elbow grease.
mrfxit,
Jun 12, 6:16pm
Should be 4 screws on the outside, from memory. Whats the model numbers on the tail lights!
The 4 screws hold EVERYTHING in, including the base unit. There won't be any screws on the inside. Somebody "may" have sealed the bases in to the frame
Jun 12, 7:29pm
No, that's the older model. The '94 Surf has two screws on the inside edge and can only be accessed once the tail gate is down.
mrfxit,
Jun 12, 8:38pm
LOL oh ok, there must be some cross over models then because they are listed as being 89 up to the 96 models. Maybe theres some confusion going on between Hilux /Hiace & Surf models Well that has me screwed then because my Surf take 6 screws each.
Jun 13, 10:20am
The shape changed in 1989, ie. N130 chassis, went up to 1995, early 130 chassis Surfs had reverse lights mounted on either side of the number plate. The older shape Surf (with fibreglass rear cab) was made from 1984 to 1989. Those models had 6 screws in their tail lights.
mrfxit,
Jun 13, 1:41pm
Hadn't seen the 2 screw lenses on any Surfs before From 84 to late 88 they had 6 screws From 89 to 96 they had 4 screws
What reg as "Surf" models had 2 screws I don't know because most models sold here on TM state 84 to 88 (6 screw)or 89 to 96 (4 screw)
Maybe it's the early Prado that had 2 screws
