Just clutch or gearbox too?
Page 1 / 3
akd100, Jul 15, 4:36pm
My clutch is stuck in and I can't change any gears, it got stuck up when I went from reserve to first. Just wondering if it could be the gearbox too, or just the clutch.And how much for a new clutch in a nissan pulsar!Approx of course.
skin1235, Jul 15, 4:55pm
pedal stayed on the floor!
nzfatie, Jul 15, 4:56pm
I'm not sure what stuck in and stuck up mean, but if you can select all the gears with the engine off the gearbox is fine.could be a broken clutch cable!
skin1235, Jul 15, 4:58pm
lost the rod between the slave and the arm and now the piston is full out and the pedal is high and won't move!
mugenb20b, Jul 15, 4:59pm
I thought that Pulsars had a cable clutch.
nzfatie, Jul 15, 4:59pm
Don't Pusars have a cable clutch!
skin1235, Jul 15, 5:02pm
was gonna ask the converse, don't they have hydraulic! lol
but if cable he/she can explain just what the pedal is doing
nzfatie, Jul 15, 5:04pm
Without starting a gender war, many women have trouble explaining mechanical problems!
mugenb20b, Jul 15, 5:05pm
That would depend if he/she had tits.
skin1235, Jul 15, 5:06pm
if she I hope she has, or converse if he I hope he hasn't
nzfatie, Jul 15, 5:08pm
Check their profile, I wouldn't think there's many men around called'Amber'.LMAO
akd100, Jul 15, 5:09pm
Yes pedal stayed on the floor.No can't get any gears now.
Lol I should hope not!And yes I agree, it is hard to explain mechanical problems.
modie61, Jul 15, 5:10pm
Can you select gears when engine is off ! I mean move the lever like normal !
skin1235, Jul 15, 5:12pm
gotta be the cable eh
modie61, Jul 15, 5:14pm
Is the car in gear now ! Like was it in a gear when the pedal jammed on you !
nzfatie, Jul 15, 5:16pm
Clutch pedal on the floor and you can't select any gears.sounds like the gearbox has fallen out.!!
akd100, Jul 15, 5:17pm
Well I reserved out of the drive way normally, then went to put it in first and the pedal stuck up, made abit of a noise and then managed to get it in neutral, but can't get it in any gear now.
Ahhhh shit, that sounds expensive!
skin1235, Jul 15, 5:18pm
tell us quietly that you were not hard out in reverse then slapped it into first while still rolling backwards
modie61, Jul 15, 5:18pm
Was the gearbox noisey before !
akd100, Jul 15, 5:19pm
Lol no, definately had stopped.
nzfatie, Jul 15, 5:20pm
Yeah next time get a Pulsar auto, they're way better.just sold my daughters one with 220,000 kms on it, still running like new!
akd100, Jul 15, 5:21pm
Ok, just going to double check that I can't get any gears.I couldn't then, but did get abit of a fright, so back in a minute.
