You will have to get the car to your mechanic or get the cuzzies round and fit a new cable,its not that hard to do.
akd100,
Jul 15, 5:35pm
Yeah, I just wanted to see if I could get gears, won't touch anymore.
akd100,
Jul 15, 5:36pm
Yep will get it to the mechanic, was just wanting some advice in the mean time.
akd100,
Jul 15, 5:36pm
Well I'm sorry that I confused you so much, but thank you for your help!
modie61,
Jul 15, 5:36pm
Good luck with the car.
akd100,
Jul 15, 5:38pm
Thank you, feeling a lot better now.Thanks for your help everyone.
skin1235,
Jul 15, 5:41pm
thats fine, putting it in gear and then starting the engine proves the clutch itself is fine, the gearbox is fine, and the issue is a broken cable only ---- ---- but do not do this if you do not have the room or the nouse to deal with the movement and eventual position the car will end up in
I suggest you do not do this, leave it for the mechanic
akd100,
Jul 15, 6:01pm
Yip I may not no anything about the mechanics of a car, but I do know what not to do.
snoopy221,
Jul 15, 6:28pm
End of the day it's sounding like an external part-(Clutch Cable) rather than an expensive gearbox out job.
akd100,
Jul 15, 6:47pm
Cool, thanks, because I hadn't been able to get it into gear early, I thought there may have been two problems, but now that I can get it into gear it is sounding much better!
phillip.weston,
Jul 15, 6:53pm
I would guess it's the pressure plate, probably some broken fingers!
akd100,
Jul 15, 7:09pm
Mechanic is going to come and look tomorrow, I just wanted to know so I could either sleep tonight or worrying about how much it's going to cost, but I'm feeling good now.
