does the head have to be removed to helicoil a spark plug thread or can it be done in place.blew one spark plug clean out of the hole in my toyota hiace and the threads nackered.
msigg,
Jul 15, 6:42pm
I would say its got to come off. one tiny bit of swarf left in there and it could stuff the bore.
les6,
Jul 15, 7:30pm
friend drilled out a sparkplug for me and just loaded the drill with grease,drilled slowiy and cleaned it often,changing drills if they got too hot.We blew it out with compressed air and then fired it up with no plug,still going now with no apparent problems!I suppose it depends on the value and/or age of your motor!
unclejake,
Jul 15, 7:37pm
The vast majority of the time it is done with the head in-situ Fuglyduck.
Find someone careful and you have abetter chance of the engnie lasting years and years
fuglyduck,
Jul 16, 3:40am
thanks for the advice will send it to the mechanic this weekhe,s a good carefulchapso hopefuly no dramas
Jul 16, 6:23am
As per the feedback from Les 6. But do be aware that a mechanic may refuse or say all care no responsibility re the swarf.
beblowin,
Jul 16, 6:55am
we took a van to a engineer to get 1 replace, it looked like tricky job, but they had all the gear to do it with the head in place, just a warning if the helicoil is not locked in correctly it can came out with the sparkplug when changing them.
twink19,
Jul 16, 7:10am
have done it in place, used a 1/4inch piece of copper sealed to vacuum cleaner hose and sucked it out
hondalova,
Jul 16, 3:24pm
engine reconditioners in cambridge did a heli coil on a ford courier FE motor. it lasted about 5 years until it popped the plug out about 6000rpm. we had it re- helicoiled and goes mint stil. done in 10 mins while still in ute.
trader_84,
Jul 16, 3:32pm
Yep, this. And if theres a few shards of alum (is the head alum!) its all going to be gone after a couple of revolutions!
alfred011,
Jul 23, 8:56pm
No put grease on tha drill and tap ,fit helicoil then crank over motor with sparkplug out,any crap will get blasted out.
motorboy2011,
Jul 24, 5:58am
or sucked in
