Commodore 304 injected
hotrods1, Aug 7, 6:19pm
HI have a commodore with a 304 injected motor in it ,took battery out to charge it up. Put battery back in and now it wont start ,seems to be flooding it . Any idea what could be the proplem.!
beblowin, Aug 7, 6:34pm
if its cranking and not firing try checking for spark or spray engine start into the intake hose, has a check light come on!
hotrods1, Aug 7, 6:42pm
no check light that i know of this motor is in a vc commodore , Trys to firer but then nothing. but the smell of petrol.
beblowin, Aug 7, 7:05pm
check spark or fouled plugs, any thing can go wrong with engine transplants, bad earths, ecu faults !
joescmoe, Aug 8, 7:31am
Can you hear the fuel pump turn on when the key is turned
howz_that, Sep 21, 10:59pm
Was it running in the carbefore battery was removed!
