1991 double cab hilux 2.8d not starting.
whiteguy1, Jun 18, 2:17pm
Thought battery was too flat so tried jumping but no use, then put battery on charger overnight and tried again. Went first time and was good for the day, wouldn't start next day so went an got a new battery today. Turns over fine but wont start, hadn't been used for a good 3 months before starting it the first time a couple days ago.Any ideas of whats wrong, thinking maybe glow plugs!
bjmh, Jun 18, 2:29pm
is there a wire that powers fuel shut off solenoid.around the back of the injector pump.check it hasn't fallen off or broken
mugenb20b, Jun 18, 3:36pm
Glow plugs, glow plug relay, fusible link or the timer.
mugenb20b, Jun 18, 3:46pm
Another thing to check is if the glow plug light comes on. If it does, how long does it take before it goes out! And when it does come on, check for power supply at the buzz bar.
snoopy221, Jun 18, 3:51pm
Dead primer pump on fuel filter housing allowing fuel to drain back overnight.
Hand prime before cold start.
