How do u change a full time 4wheel drive car.
dyln.sampson, Aug 9, 7:00pm
into a 2wheel drive!
mugenb20b, Aug 9, 7:02pm
Well, that depends on the car.
thunderbolt, Aug 9, 7:02pm
Remove a drive shaft!
dyln.sampson, Aug 9, 7:03pm
its a mits galant vr4 1996
ralphdog1, Aug 9, 7:03pm
Sell it and buy a 2wd one!
dyln.sampson, Aug 9, 7:04pm
i want serious answers
mugenb20b, Aug 9, 7:05pm
What's wrong with AWD!
dyln.sampson, Aug 9, 7:06pm
just want two wheel drive. its a project car so im going to do that first. im doing my own little experiment
markfal, Aug 9, 7:09pm
you can't make it 2wd. best to sell it and buy a 2wd one.
dyln.sampson, Aug 9, 7:10pm
yea u can.iv seen a couple of galants with two wheel drive
ralphdog1, Aug 9, 7:11pm
I don't think that is considered a serious answer by the OP.
thunderbolt, Aug 9, 7:11pm
If you know the answer, why bloody ask!
vag.central, Aug 9, 7:12pm
You will need to remove the drive shafts, but will need to leave the outer cv's bolted in the hub, you will also need to lock the center diff. Most jap awd cars ive seen have tiny rear axles and will be easy to break
dyln.sampson, Aug 9, 7:12pm
cos i know u cant answer it!
thunderbolt, Aug 9, 7:15pm
Newsflash Princess, I could get through the rest of my life without ever needing to know how to modify an outdated piece of crap to do something it was never designed to do.
Come back when you have a real question.
ralphdog1, Aug 9, 7:16pm
Ah, so this is an exercise in showing all us dumb idiots how smart you are!
Well done, I bow to your superior intellect
NZTools, Aug 9, 7:16pm
The rear end is desgned to handle 50% of the engines power at most. Even if you do manage to lock the centre diff and direct all the power to the rear, it will pop very quickly.
dyln.sampson, Aug 9, 7:16pm
hahahaha that could work. but no
dyln.sampson, Aug 9, 7:18pm
hahahahah
mugenb20b, Aug 9, 7:23pm
Do you want to make it FWD or RWD!
mugenb20b, Aug 9, 7:27pm
True, in that case he doesn't need to do anything to make it a "2WD" car.
wrxnz1, Aug 9, 7:36pm
dyln i dont know if its the same for a galant but in a wrx you just have to weld somthing to make it rwd my m8 has done it to a few he is a mechanic think he said you weld a nugget! or somthing and if you want to make it 4wd again the part cost around 300 forreplacement part
hopefully there will be someone that can explain better than i can instead of all the fools that dont want to help you
carkitter, Aug 9, 7:51pm
All these posts and no-one suggested fitting a FWD gearbox!
I have a mate who used to have a Mazda 323 DOHC turbo in FWD. It weighed around 900kgs while the AWD version weighed 1200kgs. To give the two models similar performance Mazda put short gearing in the AWD and tall gearing in the FWD. Second gear in the FWD model my mate had would reach 110km/h. Up the horsepower to overcome the gearing and you have a great drag car.
Find the right FWD gearbox and final drive ratio and you'll get significantly better performance from your project due to the weight reduction. Sort the suspension out properly and it'll handle better too.
mrfxit, Aug 10, 6:46am
LOL & so true.
Ok heres thetruth .
On the suggested mod & to get good reliability, you have several possible problems
If wanting to convert to Rwd, the problem is finding a suitable gearbox because the engine is normally a sideways fitment in the engine bay which would automaticly remove normal inline Rwd gearbox's
If wanting to stay with Fwd, then the problem is not in finding a suitable gearbox, but in finding 1 strong enough to withstand the total amount of power that WAS previously split between 2 diff's.
The same strength issue will apply to modding the Awd gearbox to a Rwd/Fwd plus upsetting any computers fitted & speedo ratios on that vehicle
mrfxit, Aug 10, 6:55am
As carkitter suggested, finding the right fwd box would be the best & simplist bet.
Add to that, you can swap over the factory rear axle setup as well & avoid a heap of trouble when it comes to getting it certed.
Pro's on the cert are factory fitted parts including .
Body strength/engine size & mounts / front suspension/ brakesetc etc.
The gearbox swap "it's self" is not a cert issue, but the rear suspension mods are & that would leave you some $$$$ for more serious mods to add to the cert
