Hiace van engine into Hilux 4x4 .
trader_84, Jul 21, 12:41pm
96' van with a 2.8 diesel engine . are these the same motors that came out in the 93' LN106's! And do they drop into the trucks ok .or are there differences like throttle, mounts etc. Cheers.
ozz1, Jul 21, 12:59pm
. sump& pick up , oil filter housing, exhaust manifold. steelengine mount brackets. etc.butjust put both motors side by side. lookclosely & swap parts over.before trying to fit.andis sweet.costsabit in gaskets. etcbutdoable.just look before you leap. :)
trader_84, Jul 21, 1:05pm
Cheers, thanks man. The luxy truk hasn't actually got a 2.8 in it at the moment . its got a 2LT in it. And I was just looking to upgrade . I wonder if some the 2L stuff is interchangabe with the 3L stuff! I'll have to do what you reckoned and have a side by side look see. Cheers.
mugenb20b, Jul 21, 3:35pm
2L and 3L look identical, so parts should be interchangable.
mrfxit, Jul 22, 7:39am
Pre 89 2L-T is different to the post 90
I think most 2.4L /2.8L /3L 90 onwards to about 96 are the same block mountings in commercial type vehicles
