wheel hot to touch what could it be rear one side only.
a18a,
Aug 8, 10:43pm
a clown
ev1lz,
Aug 8, 11:05pm
a bearing or brakes, doubt its a clown, they aren't hot to touch
thewomble1,
Aug 8, 11:24pm
jammed/sticking brake
chebry,
Aug 9, 4:36am
If its that funny.Laugh
fiatracer,
Aug 9, 4:53am
handbrake. Or clown
zak1998,
Aug 9, 3:51pm
Also get the feeling you get when you pulling a trailer but don't have one on. The wheel is not wobbling when I jack it up
unbeatabull,
Aug 9, 3:58pm
Brake is dragging/jamming/sticking. Could be a seized slide, piston, backing plate on pads, something jammed in there etc.
johnf_456,
Aug 9, 6:55pm
Please get it looked at asap by a mechanic, it is most likely a issue with the brakes.
jmma,
Aug 9, 7:12pm
Yup, you should listen to what this fella is telling you, He really knows what he is talking about.
johnf_456,
Aug 9, 7:18pm
Well I see you haven;t provided anything other than a pick myself. The OP needs to give us more information, where you been all this time!
ml6989,
Aug 9, 7:38pm
jmma, please refrain from upsetting John. We are all here to help and cheap shots do not always go down well! Anyway OP have you had a wheel off lately, possibly loose wheelnuts!
extrayda,
Aug 9, 7:43pm
I'll jump on the bandwagon. 1/. A clown. 2/. A flat tyre (maybe just at the bottom). 3/. Mother in law stuck in the wheel arch! 4/. Wheel bearing / brakes / handbrake.
More info.Is it noticeable at low speed! When it was jacked off the ground, did you try spinning the wheel by hand (brakes off obviously, and in neutral if RWD).I am assuming that the car is jacked up safely, and won't roll away / drop on you and crush you if the brakes are off :-)
extrayda,
Aug 9, 7:43pm
I'll jump on the bandwagon. 1/. A clown. 2/. A flat tyre (maybe just at the bottom). 3/. Mother in law stuck in the wheel arch! 4/. Wheel bearing / brakes / handbrake. 5/. Wheel balance / alignment (shouldnt cause the wheel to become hot though).
extrayda,
Aug 9, 7:44pm
By WHEEL is hot to touch, I am assuming you mean the metal part of the wheel, not the tyre.
jmma,
Aug 9, 7:50pm
Give the guy a compliment and get jumped on (o:
zak1998,
Aug 10, 10:49am
Sorted the brakes were rubbing due to the piston stuck
thejazzpianoma,
Aug 10, 10:54am
You do realise that you have just upset him by not using his correcttitle don't you!
jmma,
Aug 10, 1:24pm
That's good news, better than piston broke (o:
Aug 10, 1:43pm
Everyone's piston broke on Fridays.
floscey,
Aug 10, 1:44pm
wheel bearing!
tazcsv,
Aug 10, 1:45pm
What happened to the clown!
Aug 10, 1:48pm
He already showed up. Post 9.
strobo,
Aug 10, 4:27pm
Emphasize. "pissed on broke " tryand stress the sylllables please ! buuuurp
ml6989,
Aug 10, 7:28pm
Yes Jazz, I do, but that is all part of the fun and he has let me down cos he failed to bite!
