Had 3 quotes on my 1999 mitsi l200 2.4 single cam 16v 4g64 for cambelt replacement priced from $1.050 to $1250 is that really what the jobs worth or not
gmphil,
Aug 9, 4:20pm
Sounds a bit expensive would have thought bout 8 hundyish Carefull tho u may find cheaper if u ring round check reputation if possible
supernova2,
Aug 9, 4:29pm
I can get the pair of belts for $30 so the labour must be a lot to get it out to $1250!Water pump about $50 and didn't price the tensioners.
phillip.weston,
Aug 9, 4:53pm
that's an easy engine to do! I say keep shopping around and use aftermarket parts. Parts should be no more than $300-400 including water pump, auto tensioner and tensioner bearing(s).
j.feck,
Aug 9, 6:47pm
I thought it seemed a bit high the mitsi dealer who i thought would be the highest came in the middle will get a few more quotes tommorrow thanks all ps labour charges are between 90-110 per hour
fryan1962,
Aug 10, 5:09pm
I have done mine a couple of times it is easy job.just look around
cowlover,
Aug 10, 8:48pm
3 hours should do it in a L200
