Just recently, the lights on the dash of my big horn have been lighting up and switching off randomly. its running fine but what would be causing this to happen!i recently had the turbo pipe or whatever replaced and it is since i got it back from the mechanics that this has been happening, any ideas !
bigfatmat1,
Aug 23, 9:26am
alternator
wind.turbine,
Aug 23, 4:20pm
can you test the battery voltage! test it while the car is not running then test it while is is running and then turn the headlights etc on and see if the voltage starts to slowly drop. if it does not maintain at least 13V while running then you may have an issue. also check your battery leads for corrosion
bigfatmat1,
Aug 23, 4:54pm
when you replace the alt replace the charge relay as well never a cheap job on a massivehorn
