Mitsubishi Diamante
dennis15, Sep 8, 2:06pm
I have a 1997 Mitsi Diamante 2.6l automatic. The automatic is coming up with a fault flash. It drops from 4th to 3rd gear and the neutral flashes while stillin drive. Once you stop, turn engine off and then restart all ok. I have been told it is a sensor fault. Does anybody know what sensor it might be! Cheers Dennis
mugenb20b, Sep 8, 2:08pm
No. The fault code can only be retreived by a scan tool and only then you'll find out what the actual fault is.
savanna71, Sep 8, 2:20pm
More then likely 22, input shaft speed sensor
intrade, Sep 8, 3:05pm
are these already obd 2 diagnostic!
dennis15, Sep 8, 4:23pm
Have had the car diagnosed but can't remember which of the 2 sensors it was. Have replaced the sensor on top of the gearbox near the filter but need to know where to find the other one. Please help. thanks
