AU falcon stereo removal. I39ve recently removed mine by using coathangers bent into a u shape with small notches at each end bi
kiwirod,
Sep 25, 3:23pm
I've recently removed mine by using coathangers bent into a U shape with small notches at each end , bit of fiddling but works fine. have a look at the ones for sale on here to give you an idea of what you need to make.
kiwirod,
Sep 25, 3:27pm
Auction 408732737- note that notches need to be slightly lower down for falcon .
icemans1,
Sep 25, 3:39pm
same as on the commodore - i got an old thick wire coat hanger and made my own, piece of p!$$ to make and pull stereo out
richard198,
Sep 25, 5:44pm
Similar technique for a lot of stereos. The trick is to get all four prongs disengaging the lugs all at the same time!
ema1,
Nov 18, 9:46am
I got a set of 2 DIN FORD stereo removal keys real cheap from the UK and took only 4 days to get here, heck that's faster almost than NZ delivery by NZ Post.
