Noticed my warning lights came on and the charging volt meter went up to 17 volts. Im told it might be the regulator on the alternator. Could it be anything else or is it more open wallet surgery !
dent,
Sep 11, 5:11pm
Id check with a multi meter just to make sure but it will be a regulator issue. Alternator will need to come out and be stripped down.
bubbles244,
Sep 11, 5:20pm
Is that the dealership or the alternator!
jsc1,
Sep 11, 5:50pm
yea guy with a multimeter said it waent yo to 16 volt
supernova2,
Sep 11, 5:58pm
Is 16v that excessive!Just asking.
jsc1,
Sep 11, 6:04pm
I was told 14 is the top limit
dent,
Sep 11, 6:30pm
Calcium Battery's often need up to 14.8v to be charged correctly. But 16v is defiantly on the high side and you will end up with over charging and boiling of the battery. Shortened battery life and other issues.
tnt423,
Sep 11, 6:38pm
Would 28volts be to high on a 24v Nissan Safari!
gammelvind,
Sep 11, 6:44pm
28 volts equivalent to 14 volt on 12 volt system, so all good.
tnt423,
Sep 11, 6:53pm
Ok my year old batteries have the red thing showing up on them, what checks can be done to see if it the batteries or the charging system thats playing up.
bigfatmat1,
Sep 11, 7:03pm
could be regulator could be a rotor fault as well. the alternators are cheaper to fix than nissan ones. also cheaper to rep;ace than nissan ones
Sep 11, 7:06pm
for a calcium battery 16 volt is ok they need high voltage you should rev it and see if it goes even higher at higher rpm that would indicate regulator fault if it went higher and higher with more rpm
bigfatmat1,
Sep 11, 7:15pm
this is true but however his batt light is on and the set point for that regulator is 14.4 so clearly a fault
tnt423,
Sep 11, 8:13pm
Ok cheers for the info, the batteries (SuperCharge golds) are not even half way through a 24month warranty, 28volts is the max it goes to, sits just above 24volts at idle. Is there any way to test a battery!
