Subaru Legacy Single Turbo conversion
whangaripo, Sep 19, 12:33pm
So i need advice from somebody who has either done this or has seen it done, i have a bh5 subaru legacy twin turbo at the mo, but has blown primary turbo so i am converting, now i am removing the twin turbo vaccuum system can i just cut the plugs! can i cut it right back to wiring loom! aybody on here wanna come give me a hand! :)
splinter67, Sep 19, 12:44pm
Yep you can it probably wont run
shakespeare6, Sep 19, 1:17pm
what ECU are you now using wrx!
whangaripo, Sep 20, 4:16pm
will still be running vaccum just after market coz it wont run off the standard twin turbo set up
Im not sure about ecu shudnt need to change as not doing injector or any fuel side at this point
matthew_129, Sep 20, 4:59pm
x1
At the rate your going its not going to run.
take a look at www.clubsub.org.nz
theres some threads on there that detail the process you need to follow. Be wary that some of the wiring that goes into the vaccum box (black box) is for your map sensor and boost control solenoid which you will need to retain. You also need to change to a WRX or aftermarket ecu (ie. link) as your twin turbo one will throw codes because its no longer connected to the twin turbo setup and the car will not run
