Subaru Legacy RS idle problem
meow_mix, Sep 18, 2:42pm
Once the car has been warmed up for 5-10 minutes, the idle drops down to about 700rpm, then sometimes the engine starts shaking and then cuts out.It does this about once or twice a week, not every time,It's like the engine is trying to idle too low causing it to conk out.This is becoming slightly dangerous.Any idea what the problem could be!It's only done this for about the last month.Car is a 1993 Legacy RS twinturbo.
intrade, Sep 18, 3:34pm
chrck engine light on at all!
meow_mix, Sep 18, 4:10pm
No the check engine light has not come on, thanks.
mjbee., Sep 18, 5:28pm
check your vacum hose
meow_mix, Sep 18, 5:47pm
Which one!
whangaripo, Sep 19, 12:36pm
check all vaccum hoses even start too look at your 02 sensor i had this issue with my 98 subaru legacy could possibly be a coil!
meow_mix, Sep 20, 9:26am
Thanks, won't be a coil I put new ones in a couple of years ago.I will check all vacuum hoses and O2 sensor, cheers.
new2cycling, Sep 20, 12:14pm
Air Flow Meter.
jokerboss, Sep 20, 12:27pm
lol : warming it up. but yea sounds like a split hose of some sort (TT's have heeeaaaps) : just enuff time for a pipe to warm up / flex, unplug afm and see if that changes anything (if it doesnt then its not that)
