Has anyone put one on a holden 304,any issue with spacing the power steering pump. Cheers
bent_ate,
Sep 18, 6:15am
I did one on my Chev (SB), I had to make some crank pulley spacers out of alloy plate, to line up powersteer pump, at the same time it spaced the belt position (on the gilmer) out and centerd it more on the waterpump pulley which in turn was lined up with alternator, I used screw cap type bolts on crank pulley, from what I remember normal bolts are near on impossible to get in, hope this helps with your Holden setup
