Easieast way to replace a front park light. On a 94 hiace please
claire351,
Sep 15, 3:03pm
on a 94 hiace please
Sep 15, 3:30pm
Open the door, remove a couple of screws from the inside of the door opening (which hold the lens), remove lens, replace bulb.
claire351,
Sep 16, 6:15pm
There are no screws visible
Sep 16, 6:36pm
depends take a picture. them towneace are a wee .iffy also to change bulbs screw are hidden at times whole light then comes forward once a hidden bolt is undone as per post 2 check inside door where the light is be between the hinges a 10mm spanner then light pulls out forward probably
