Can someone tell me how much a full service goes for these days!Thanks.
splinter67,
Oct 16, 12:20pm
On what and where and what do you expect!
jljjn28,
Oct 16, 12:32pm
oops sorry - it's a vehicle engine service, where they change the oil and filters etc.Thanks.
splinter67,
Oct 16, 12:44pm
Now we know what you expect what type of car is it and what city are you in!
gadgit3,
Oct 16, 12:44pm
What do you call a FULL service! and on what vehicle as this makes a huge difference with the price of fluid.
gadgit3,
Oct 16, 12:45pm
With the info suplied. A full service will cost you $220 to $1500
jljjn28,
Oct 16, 12:49pm
Holden Commodore 1996 - full service would be changing oil and filters etc.in Dunedin.Thanks.
gadgit3,
Oct 16, 12:53pm
So you just want the oil and filter change! not a drive line check/lube, brakes and suspension check clean and adjustment. Lube doors windows and adjustment. Wash and vac!.
jljjn28,
Oct 16, 12:55pm
No it would just be the oil change and all filters changed.thats all.
gadgit3,
Oct 16, 12:58pm
Well thats far from a FULL service. Now where do you plan on taking your car! to a Dealer or local workshop. or a place like pit stop ! the answer to this one will make a huge difference to price also
ken171,
Oct 16, 1:36pm
Give Oil Changers a ring,03 456 4424. Midland St. Dunedin.
Oct 16, 1:37pm
the problem is you need to know what was done on the car what the milage is as different things need doing depending on car and milage . to name 1 every 24 month coolant change and brake fluid exchange thatsjust one of loads of other things that may or may not be included on a full service.
splinter67,
Oct 16, 1:40pm
good call
splinter67,
Oct 16, 1:41pm
Too complicated you need to read what the op has posted dont try and confuse them
flagheaven,
Oct 16, 1:43pm
just had ( yesterday )2006 VZ SS holdenengine oil change - filter and diff oil changed - $218.50 including GST.
jljjn28,
Oct 16, 3:10pm
lol.yes read that and felt very confused.
jljjn28,
Oct 16, 3:10pm
Thank you, that was helpful.
stevo2,
Oct 16, 4:12pm
From $80 for just oil and a filter. That is not a "full service". That is a "minimum Service" You get something a bit more decent for $200 like antifreeze will be checked, brakes checked adjusted, air filter cleaned etc then for a bit more you can get coolant replaced, new air filter, and a light tune up such as plugs cleaned re-gapped or replaced + more. Remember "You get what you pay for"
afer_daily,
Oct 16, 4:52pm
full service ! i havent been down K rd in a long time.
splinter67,
Oct 16, 4:56pm
Read post 16 your wasting your time they aint car people you may as well type in Japanese
sw20,
Oct 16, 4:57pm
johnf_456 tells me its about $200 an hour.
stevo2,
Oct 16, 5:04pm
How does he know! Does he give or receive!
doctor_evil99,
Oct 16, 5:28pm
Does it matter!still require plenty of lube
sw20,
Oct 17, 7:01pm
Probably still cheaper than a wife
