I only get 8 km to the litre of diesel.I've had it 3 years and it has always been the same,maybe a bit more on a trip.Change air filter regularly.turbo OK,have disconnected the exhaust emission pots on the manifold 3 months ago as it was blowing back soot into the engine well.any suggestions.
chebry,
Oct 10, 5:52am
Your getting 36 mpg out of it and you expect more, aint gunna happen too much weight and the aerodynamics of a block of flats are against you to begin with, an efficient intake and exhaust may help but great economy is beyond this thing
hi-ling,
Oct 10, 6:02am
Auto or manual. I've had 3 manual 3.1s and they've all averaged about 9.5-10 km/l, but I had 1 auto and it was a bit less around 8-8.5 km/l The 3.1 is not the most economical engine out there, but they can be improved, both performance and economy wise. First thing to do is block of all EGr valves, fit a full 3 inch exhaust with a straight thru muffler, right from the turbo back. Fit a bighorn intercooler and then turn your fuelling up, between 1/4 and 1/2 turn. You can also increase your boost pressure to just under 11 ponds boost. What you'll have then is a diesel that wil pull like a group of schoolboys but you economy will go up, My last 1 I was running 15 lb boost and all the other mods and manual, and on a trip up the island, could get 12-12.5 km/l and even towing a tandem axle trailer with a 88 Camaro from ChCh to invers, I was still getting around 8;5-9 km/l
hi-ling,
Oct 10, 6:04am
8 kms per litre isnt 36 mpg, its 22.7 and thats low/\.
chebry,
Oct 10, 6:08am
oops my bad vs a petrol version its ok but yeah nah
morab,
Oct 10, 6:33am
thanks.you beat me to it. my MU is an Automatic.
splinter67,
Oct 10, 6:48am
When did you last change your diesel filter
Oct 10, 6:55am
you should have added flashlube or winns edt to your fuel. you probably now have a well rooted injector pump with premature worn injectors. You can still go to partsmaster and buy 1 liter flashlube . Also your intake will need to come off amd the EGR cleaned and deleted . if it dont smokes like sometimes gray and sometimesblack for longer then you got a chance of saving your fuelinjection system from total destruction.
morab,
Oct 10, 7:31am
fuel filter changed 10k ago.EGR was blocked/disconnected 3 months ago.always black never grey.exhaust. so what is Flashlube gonna do for it!
geminidragon,
Oct 10, 7:55am
i use the wynns edt on my 3.1
Oct 10, 7:58am
its going to swell the selas back up prevent them from going brittle and brings back the lubrication in to the diesel that is missing in ulsd-fuel there is noumerous threads on here about this and i told people since ages about this problem, its to do with how they remove the sulfur from diesel the more sulfur the more hydrogen is used , making that particular batch of fuel even less lubricating.the injection system relies on lubrication and if it dont gets it it will start wearing out change timing or even seeze up completely there are no seals on the high pressure pump side its just the precition madeparts that are sealing them self and if you know mechanics then you know what these parts will do with insufficient lubrication. flashlube winns edt and chemtech also prevent water bonding to uls fuel as that is a further problem of the new fuel. chemtech is only a lube and dont claims to prevent seal shrinkage and i know flashlube works if its not to late as you cant fix damage you can only prevent it.
splinter67,
Oct 10, 8:03am
Change your filter I used to change deisel filter every time I changed the oil airfilter and oil filter every second oil change never added anything to my diesel never had seal problems
splinter67,
Oct 10, 8:16am
x1
Do you sell this stuff
Oct 10, 8:18am
no i dont i fix diesel engines for a living so i know what i talk about usually for commonrails i would fit dlc injector nozzle they can resist ulsd fuel for longer without premature wear.
chebry,
Oct 10, 8:40am
I dont see this stuff being put in trucks so how much use is it, a seal kit is no big deal to fit to older diesels and newer models are designed for ULSD fuel but hey thanx for the snake oil pitch
scoobeey,
Oct 10, 10:52am
NO snake oil :) I use flashlube and pump never been looked at! .Mates wagon had a small leak and it actually slowed it down :)))
splinter67,
Oct 10, 10:59am
And what do you drive did you have a problem to start using flashlube
geminidragon,
Oct 10, 8:30pm
i use 50 mls of wynns edt to 75 litres of diesel ,can i double it to 100mlsintrade or leave it like that ,i know it cleans the injectors
next-to-normal,
Oct 12, 12:30pm
motor up, helps
Oct 12, 12:38pm
no it wont motorup goes in the engine oil and dont helps lubricating the diesel injection system
mram,
Oct 13, 10:52am
The 3.1 can be a thirsty dog if not in a good state of tune, I had a bighorn that, even if driven sedately only would return 14-15l per 100km, and it didnt seem to blow excessive smoke, I don't know where it went!
geminidragon,
Oct 13, 12:31pm
i average 650 kms to 75 litres of diesel in my 3.1
scoobeey,
Oct 15, 9:23am
YES i did have a problem .!Major sulphur levels robbed from fuel which NO LONGER lubricated seals .:)
splinter67,
Oct 15, 9:47am
So what was your problem ! and what are you putting it in
Was it leaking and did it work
scoobeey,
Oct 15, 2:44pm
no problem at all just didnt want a herendous bill like many hundreds of others did due to pump seal failures
