googled this and seems to be a common fault, I've changed the alternater and was running as normal for a week, but now the lights on dash have all come back up again and has that ringing sound like when you forget to turn yr headlights off. Batterys fully charged and even tried another battery from another vehicle and it still does the same thing, googling is pushing me towards my ignition switch as some have changed there alternaters and moved towards ignition.
thejazzpianoma,
Oct 11, 4:07pm
Which series Estima might be helpful.
snoopy221,
Oct 11, 4:08pm
Does it do it in forwards and not in reverse!might be helpful.
cye2,
Oct 11, 4:21pm
its a 93 toyota emina estima van 2.2-litre Diesel, it does it in both forwards and reverse
snoopy221,
Oct 11, 4:30pm
Well there ya go. However have had same/similar problem with landcruiser-unless you enter the right SPECIFIC wording in to google-ya'll be there for a week. However if you get a helper to **observe** the lights while you wriggle the main 3 pin plug on the back of the alternator you will find it is loose terminals in that plug causing the lack of a common earth for the lights. [Estima is a little bit diferrent due to alternator mounting on the sub shaft] Remedy-remove plug tighten terminals inside plug with a small scredriver refit plug to alternator
snoopy221,
Oct 11, 4:32pm
!Happens when ya remove and refit same plug and it getzzzz a week of betta contak.lol!
thejazzpianoma,
Oct 11, 4:34pm
BTW, you should be aware that those have a nasty habbit of snapping the drivers neck in even a fairly mild frontal impact. All good if you are aware and comfortable with that, but lots of Estima drivers are not aware and I only think its fair to let them know.
And next you are going to tell us no one has ever died in a fiat.
guest,
Apr 22, 2:28am
Does anyone know how to sort this problem,mine just done it today
