Loud noise coming from diff
reeb, Oct 22, 2:26pm
reckon wont be long before it seizes. ford courier only done 135 k bit pissed off.
andrea_w, Oct 22, 2:27pm
When was the diff oil last changed!
reeb, Oct 22, 2:29pm
1 year ago.
mechnificent, Oct 22, 2:30pm
Are you sure it's not a wheel bearing!
Does the noise get louder when you swerve a bit briskly around a corner!
mugenb20b, Oct 22, 2:32pm
Or checked.
reeb, Oct 22, 2:33pm
got a qoute from a garage to get fixed $1500
mechnificent, Oct 22, 2:49pm
The diff should still be fine at that mileage. I'd be suspecting a wheel bearing.
franc123, Oct 22, 3:10pm
Could be either, bearing failure in both the diff heads and axle shafts were big problems in 99-06 Couriers, many didn't get out of warranty before the bearings gave up. Water contamination and thus corrosion of the outer bearings was quite common. The usual stethoscope tests for these problems should be carried out.
intrade, Oct 22, 3:13pm
i would look if there is oil in the diff now!
m16d, Oct 22, 3:51pm
There should be plenty of Couriers at the wreckers by now. Go get a second hand one.
splinter67, Oct 22, 3:56pm
did you take it in when you got your quote
escapelife, Oct 22, 3:58pm
they were weak in the gearbox too
outbidyou2, Oct 22, 4:01pm
head gaskets werent much better
escapelife, Oct 22, 4:11pm
new mazda bounty parts fit and way cheaper
jonthefisho, Oct 22, 7:01pm
I'd say wheel bearing , changed a mates one last week,
it was knackered.
mechnificent, Oct 22, 7:12pm
The test for a wheel bearing is very simple, you drive down the road and swerve from side to side. If the noise gets louder, it's a wheel bearing. If the noise stays much the same while swerving, but gets loader when you put your foot on and off the throttle, then it will be the diff.
