I read somewhere that you should only use subaru coolant in subaru's. Is this true or is there another brand very similar! thanks
make_a_bid,
Oct 30, 7:38pm
where did you read that! ive read somewhere that you can use any coolant in any car
shane191,
Oct 30, 7:40pm
it was on a msg board somewhere, i came across it when i was searching for info on how much coolant the radiator holds.
jason18,
Oct 30, 7:55pm
I have seen that also. I then found out castrol supplies subaru antifreeze
chebry,
Oct 31, 5:39am
Coolant is coolant if it pours in to a Subaru its subaru coolant
Oct 31, 5:41am
i would find out what coolant it runs like Vw need the red stuff super long live coolant on some 2000 onwards models to prevent coolant system issues . pays to check if your subaru needs a special higher grade coolant
