Air bags Nissan navara
jeff232, Oct 31, 3:55am
Hi anyone know how much to repack or replace drivers airbag in 2003 Navara ute cheers!
mugenb20b, Oct 31, 3:41pm
What exactly has happened with your one!
bitchwitattitud, Oct 31, 4:39pm
If it has deployed then you more than likely have to replace the airbagand the SRS computer as well. If your D22 has Pretension seatbelts then they may of deployed as too.
To change the airbag disconnect the battery.
There will be 2 or 3 plastic covers on the steering wheel, remove those to expose the bolts and use a T20 or T50 Torx bit to undo the bolts. Unplug the airbag module.
Get your new or 2nd hand airbag
Put it back in
jeff232, Oct 31, 4:49pm
Hi just want to know cost as have bought ute and discoverd airbag missing completly cheers.
grangies, Oct 31, 5:25pm
Just out of interest.
How did you discover it missing!
gammelvind, Oct 31, 5:30pm
Drove it into a wall and nothing popped.
jeff232, Oct 31, 5:33pm
Hi centre of steering wheel was squeaking went to lubricate it,just came off and nothing behind.
metallicafan21, Oct 31, 5:39pm
You do relaize you prob didnt hit the sensor, as i went straight onto a lamppost at around 60km when icy and mine didnt pop, missed it by 2mm
dent, Oct 31, 5:46pm
was the air bag light on! if it was then you should have thought about it befor you brought it. Are you sure it has an airbag!
mugenb20b, Oct 31, 5:48pm
Can you post a picture!
wasser61, Nov 1, 6:24am
What sensor are you talking about!
The sensor is a control module that generally sits inside the cable on or near the firewall.
