Have a ford tractor and the headlights and working lights on cab are dim compared withour 2nd tractor of the same model. Are off white instead of bright white. Could this be poor earth ! It is on all lights not just some or 1. Any help welcome
pettal,
Nov 10, 6:38pm
Battery condition , different bulbs , dirty lens or glass !.
carlz05,
Nov 10, 7:13pm
Poor earch can do it, otherwise the wattage of some of the bulbs can be different also standard bulbs vs hallogen.If you can swap 1 bulb try it, if it makes no difference then its poor earth.
mnstr,
Nov 10, 7:51pm
If all lights on then you turn on the hazards on they struggle and all light dim then yet starting is fine even when a cold start, I'm thinking the whole lighting system has poor earth somewhere or maybe poor power supply - yet to check volts at lights. Thanks
mnstr,
Feb 17, 4:43pm
run at cable from engine block to cab steps and lights brightened . tells me cab poorly earthed.
