Hi have been told my centre diff needs fixing. I have a 1997 auto gtb Got quoted $950 from a subaru specialist seems pricey. What exactly does fixing the centre diff intale! Cheers Shay.
a.woodrow,
Nov 8, 3:42pm
Have you been quoted for a second hand or to rebuild!
sd8888,
Nov 8, 3:59pm
I'm not sure but i do have a second hand trans. Will it need to be replaced!
girlracer2005,
Nov 8, 4:00pm
well to start the gearbox needs to come out and pulled apart then i guess they would need to go from there
sd8888,
Nov 8, 4:03pm
I should just get it replaced with the trans i have in myu garage then!
a.woodrow,
Nov 8, 4:13pm
If its a good one and has a good diff. Will bring price down a little but don't forget to allow for new trans fluid etc
hijacka,
Nov 8, 8:40pm
Subaru Automatic transmissions don't have center diffs. get another opinion. Perhaps you could start by describing the fault
suplyuparts,
Nov 8, 8:53pm
is it 4wd or fwd.!.centre diff sits inside the gearbox.The gearbox you got,do you know if its the same one in the car,!i.e model numbers.!.coz the rear diff would need to be the same as the box.
horsepower7,
Nov 8, 9:06pm
have they tryed putting some additives in it first!
sd8888,
Nov 10, 6:46pm
It feels like the power steering has gone on it amd when reversing it kind of clonks if that makes sense lol
sd8888,
Nov 10, 6:47pm
its awd btw
carlz05,
Nov 10, 7:17pm
Don't get it fixed, its usually just dirty transmission fluids, so do a trans oil and diff oil change and put some trans additives in the diff and the auto.Take the car out and do figure 8's in a carpark both forwards and backwards and it should clear up.Have had 3 subarus with this problem, 1 really bad and fixed it with fluids change and Wynns additives.
alltorque350,
Nov 11, 4:32am
REAR DUTY SOLENOID!
sd8888,
Nov 12, 4:46pm
Thanks guys will give it a go.
cp2011,
Feb 21, 9:45pm
ive used lubegaurd platnum in mineworked a treat
