Opal Zafira,Holden Zafira and Subaru traviq (from memory re exact suby model)-all the same car and as PW said basically mechanically a Vectra. I had one a year or so ago. Make sure the hinge stoppers (cant think of the right name the bit that stops the door flying wide open)arent ripped out or ripping out.
phillip.weston,
Nov 12, 1:23pm
It seems they are actually Astra based rather than Vectra based - however engine/drivetrain and mechanicals will be similar.
chebry,
Nov 12, 1:25pm
Theres one on TM locally with a rod thru the block so I guess they can be
the-lada-dude,
Nov 12, 3:09pm
hey thanks guys, and your onto it' chebry 'was thinking about bidding, but now thinking if engine is totalled, and you swap in a vectra mill, you'ld wanta hope the eng mates up to the g/b ok, then what about all the sensors etcUg !day dream--------> nightmare
jmma,
Nov 12, 3:32pm
Umm, check strap (o:
chebry,
Nov 12, 3:37pm
If memory serves theres an Astra underneath those Zafiras not the larger Vectra it shouldnt be too hard to repower one
