VW Passat 1998 cranking, not starting
batman4321, Nov 17, 11:04am
Title says it all. Checked everything, spark plugs are new and there are sparks. Fuel pump working, used device that checks for fuel pressure, it passed. Car broke down in traffic, started once after, hasn't started for 2 weeks. Battery seems ok. Radio, indoor car lights working. All ignition lights go off after ignition start. Tried to reset computer by unplugging battery leads, leaving them off for 10 minutes, and reattaching it. No difference. The car is almost about to go.
bellky, Nov 17, 11:05am
Yep title says it all: VW
v8power, Nov 17, 11:08am
Might be a visit to your local auto sparky I would say. At a guess it started up in limp home mode to get you home. Could be a number issues that would be hard to diagnose over the internet.
intrade, Nov 17, 11:10am
well disconecting the battery does squat on a vw .
Do you got a check engine light on the dashbord! on when it died!
intrade, Nov 17, 11:12am
what engine and how long since it had its sparkplugs changed!
batman4321, Nov 17, 11:16am
(AEB engine) 4 Cylinder / 1.8 litre. All spark plugs were replaced with new ones after breakdown.
satans_child_nz, Nov 17, 11:19am
ecu not opening injectors at it should! maybe try replacement ecu
intrade, Nov 17, 11:22am
Wheredid you buy this car from!
batman4321, Nov 17, 11:22am
It could be fuel problem because it did break down while it was going.i.e. the engine wasn't getting the fuel to power it.
intrade, Nov 17, 11:23am
dont be stupid satanschild its not a mitsubishi.
batman4321, Nov 17, 11:23am
car fair. 5 years ago.
wimwom, Nov 17, 11:25am
Obviously, the answer then would have been simple.put some fuel in it.
splinter67, Nov 17, 11:27am
Take it to a vw mechanic dont listen to the clowns on here that dont know a thing you cant diagnose this problem over the internet
00quattro00, Nov 17, 11:28am
omg some people come it with some stupid ideas, crank angle sensors are usualy the main culprit, only buy a genuine from giltraps, same price as the shit chineese ones, but scan it first and all will be revealed
batman4321, Nov 17, 11:30am
Here are some codes from OBD 2 computer
p1559 - vagcom
"not recognising throttle valve settings" - part name: J338 / code name: 17967
skyblue17, Nov 17, 11:34am
Fuel pump relay!
intrade, Nov 17, 11:36am
na the position sensore of the gas pedal either the one on the engine or the one on the gas pedal by the sound.
intrade, Nov 17, 11:37am
so thats the code you read out!
batman4321, Nov 17, 11:38am
No. Plenty of fuel getting to injectors.
splinter67, Nov 17, 11:39am
Where is jazz when you need him earth to jazz come in jazz
batman4321, Nov 17, 11:40am
Yes. That's all it says. It says something about basic settings. We tried to reset it.Grey area for us.
v8power, Nov 17, 11:42am
Surely a TPS fault would have it's own code!
I'm leaning towards throttle valve (trottle body) output voltage incorrect. ECU takes paramaters from both trottle body and TPS, if sense voltage doesn't match ECU logs fault code and as this is a command system limp home is initiated.
I could be wrong though but thats my guess
00quattro00, Nov 17, 11:43am
They dont have one on the pedal
splinter67, Nov 17, 11:43am
ring the vw people playing with things you dont know about can be very expensive and you could make a easy job into a major overhaul
00quattro00, Nov 17, 11:44am
It should still start even if the throttle body is unplugged
