VW passat 1999
atmorris, Nov 20, 3:36pm
Got a crack in the auto trans sump. Can not find a dipstick like a normal auto transmission. What fluid do I put in, how much fluid, and where on the transmisson do I put the fluid.
Thanks in advance
00quattro00, Nov 20, 3:42pm
There is no dipstick, would pay to have the trans serviced, replace the sump, new filter and new oil
atmorris, Nov 21, 6:12am
someone must know how to do this
intrade, Nov 21, 6:24am
yea i do you need a special tool its filled thru the drainplug and the level is by mesuring the fluids of the trans temperatur sender 30 degree celcius with vag obd2 diagnostic tools.
i recommendyou get it transportet to a auto trans rebuild place whole service will probably be 500$ with sump replacment . you can order parts here for diy but you still need vag rosstech obd 2 diagnostic tool.
site is usa so no free shipping for you i would say
http://www.blauparts.com/
intrade, Nov 21, 6:28am
if you cant find a competent plave then advanced automatics whangarei54 hanna streetwhangarei will be able to repair it them i do trust the boss will explain all things that can go wrong , I hope you did not damage the insides of the trans
intrade, Nov 21, 6:30am
