ABS fault on EVO4 cn9
bevharris1938, Dec 5, 7:45pm
Failed wof due to no abs light going on dash. Found bulb gone, replaced. Getting fault codes open lr sensor open rr sensor and a valve fault , checked lr and rr sensors , tested ok , not sure what valve fault is , should next move be maybe to change the ABS computer !
johnf_456, Dec 5, 7:47pm
Have you tried resetting the computer, i.e discount the battery for a while.
bevharris1938, Dec 5, 7:48pm
yes done that, was told that the capacitors in the mitsi computers dont last
saki, Dec 6, 2:52pm
Contact TM seller mitsi-spec does mitsi computers may be able to help
savanna71, Dec 6, 4:37pm
I would be very surprised if its the control unit, Valve fault is most likely the relay if logging DTC 51 and how have you tested the speed sensors, what are the tone wheels like have you checked the output pattern with a oscilloscope! etc etc
bevharris1938, Dec 7, 8:30pm
Thanks for your help , the abs ecu was 50% of the problem, the other fault was the last owner had installed non abs cv axels in the rear , the sensors could not pick up anything.
savanna71, Dec 8, 4:09pm
I can probably help with these bits if you need them, let me know!
