what product is best to use to seal small splits in a plastic fuel tank!
skin1235,
Dec 23, 8:43pm
a match!
skin1235,
Dec 23, 8:44pm
no, seriously, do you really want a weakened tank in the boat or the boot
xacoon,
Dec 23, 8:45pm
nope, but its for a lawnmower so those two options are of no concern.
esprit,
Dec 23, 8:47pm
POR15 do a fuel tank repair kit. It's a coating that lines the inside and seals up rust holes etc.
skin1235,
Dec 23, 8:50pm
lol, I shoulda known,
heat or aged!, lower tank or up around the top
I've sealed a quad plastic tank with a half cup of epiglass resin, pour it in and keep it moving until it sets, hasn't leaked yet and it's done some hard yards since
xacoon,
Dec 23, 8:53pm
I think it is a case of someone leaning a bit hard on the spanner when tightening the bolts, and a bit of age thrown in. unfortunately it is on the bottom of the tank, otherwise i wouldnt bother too much about fixing.
skin1235,
Dec 23, 8:58pm
so a couple of tablespoons of resin and redrill the bolt and access holes!
even a great chunk torn out can be fixed with a bit of careful bog work
xacoon,
Dec 23, 9:05pm
actually the tank has bolts top and botton, and the bottom mount is slotted, so I could just epoxy the bolts in place. right, might have to see who I can flog some epoxy off in the morning.
panelvanner,
Dec 24, 11:21am
Use emerkit/kneadit/mendent or the like, cheap and work well. Very strong and fuel proof. (Like the pun!). I have used it to repair a hole in a Carburettor Brass float, was that way untill I sold the carbs, after 4-5 years running. Also a MB fuel tank. Panelvanner.
