The "check engine" light stays on on a mitsi I just looked at. Has apparently been doing so for 2 years or so. Is this a serious issue! seems to go ok, apparently auto electrician told seller to take the bulb out ! Will this prevent it getting a WOF! Thank you.
Jan 2, 3:55pm
what is the mitshsihitzi exactly! a GDI!
shazbat,
Jan 2, 3:57pm
V6 wagon, early 90's. Not GDI
nz2293,
Jan 2, 4:02pm
is it a mivec engine
lazzo,
Jan 2, 4:07pm
If its a V6 wagon from the early 90's it must be either a V3000, Magna or Diamante, none of which had either GDi or Mivec engines in a wagon.
And no, very unlikely to be terminal.
shazbat,
Jan 2, 4:17pm
V3000 185,000km otherwise seems fine.
lazzo,
Jan 2, 4:24pm
I shouldn't think you have anything to be concerned about, especially given you're looking at a car now over 20 years old. They're a good cheap old wagon.
shazbat,
Jan 2, 4:26pm
So it won't affect WOF !
lazzo,
Jan 2, 4:29pm
That is outside my area of expertise!. but i don't think so!
Calling all WOF inspectors!.
pickles26,
Jan 2, 4:33pm
check engine light is not a woff item
cowboy110,
Jan 2, 4:38pm
My guess is that after "2 years or so" of the check engine light being on it is neither terminal nor a WOF issue.
nzdoug,
Jan 2, 4:42pm
The oil light just might mean the engines stuffed. No problem.
Jan 2, 4:43pm
1. No, but you should get it looked at. 2. That's what I would do if I was going to sell the car. 3. No.
If the oil light was on for 2 years, I doubt the engine would be stuffed.
shazbat,
Jan 2, 5:36pm
No, oil light not on. Just the "check engine" light.
lazzo,
Jan 2, 5:39pm
Could be as simple as a faulty sensor, just drive it until its served its purpose or doesn't want to go anymore, I wouldn't be worrying about it.
Jan 2, 5:39pm
Someone is trying to make their problem your problem, I wouldn't believe that story. Move on.
lazzo,
Jan 2, 5:56pm
I don't think there will be too many cheap 20+ year old cars out there that don't have issues.
Jan 2, 6:20pm
Still not particularly wise to buy something that has got an engine management issue, you'd be wanting a better explanation of the problem than whats been given. But hey if people want to blow their money on something that they knew was faulty then go ahead.
shazbat,
Jan 2, 9:17pm
OK, so it's not cheap, not a popular model, and I'm not mechanically inclined. So I take on board your comments and will walk away. Thank you all you knowledgeable peops.
theram1,
Jan 2, 9:20pm
nanu nanu
lugee,
Jan 3, 2:58pm
The funny thing about check engine lights is that they make a big fuss about benign things like a oxy sensor that went out of range for a split second, but won't tell you that a rod is about to go through the block.
Jan 3, 7:20pm
They make a big fuss because they are required to in some places.In emissionally anal places like California its actually an offence to operate a vehicle with certain types of engine management problems.We will one day live in a world where electronics will be able to completely compensate for thestupidness, ignorance and neglect of drivers towards their machinery but it hasn't happened yet.
kokako14,
Jan 3, 7:49pm
Could always reconnect the speedo. That will make it go out
arrithedog,
Jan 3, 9:20pm
! Surely if the speedo was disconnected it wouldn't work! OP didn't say speedo not working.
