Holden vx R8 2002 bodykit removal
ice_cream, Jan 19, 12:16pm
How does one remove the side skirt from this car.i dont want to damage it.are there just clips holding it or.
gunhand, Jan 19, 12:47pm
If your lucky it may be screwed on at its ends and some clips through the center.They are not held on by much. Hopefully not urathaned on.
grangies, Jan 19, 1:55pm
Lift up the rubber seal that sits at the top if the sill cover and you'll see the screw fastened clips under it that run along the length at various intervals. You need to gently unscrew them so the clip doesn't spin, then when about half way out, pull on the screw and the entire screw and clip should slide out of the hole in the body.
Underneath should be similar, but will have steel screws.
Providing that they are genuine R8 factory fitted sill covers, that is.
xs1100, Jan 19, 5:05pm
why would you want to take if off
brokebloke1, Jan 20, 7:02am
maybe cause they are bloody ugly.
most body kits are
chebry, Jan 20, 7:12am
CHUR finally someone else with eyes
