Can a broken lock cause a flat battery
purekiwi34, Jan 21, 4:34am
I have central locking on my car and the drivers side is broken and wont lock.I got a flat battery yesterday, are the two connected, could the lock that wont work cause a flat battery in any way.I checked car over and nothing else would have caused the flat battery unless ts just old now and need replacing.
My car is a 2004 and the battery looks like the original.
NZTools, Jan 21, 5:07am
If your door lock has been broken for a while, i doubt very much tha it is a cause.
8 or9 years is a good innings for a battery. Have it tested before you replace it though.
purekiwi34, Jan 21, 5:32am
its only been broken for about 3 weeks the lock. can it slowly run the battery out or is it unrelated.
chebry, Jan 21, 6:36am
Id be getting the battery tested thats ancient in battery terms and more likely at fault
kokako14, Jan 21, 6:49am
Jezz, 8-9 years from a Battery, that would have to be some sort of record.
elect70, Jan 21, 2:27pm
Could if theactuator was stuck engagedmy disco did itbiffed it out .fixed theproblem
