Can't get a wof because the ABS light won't go out.Keeps coming up with the fault.If the G Sensor is faulty would it be safe to try & find a 2nd-hand one! I've already blown this weeks budget! If not then where would i purchase another from! Google is not my friend today.thank you
1995 Diamante
yogibearz,
Jan 24, 7:08am
You could try for a second hand one but its all ways a risk. You would need to get the exact same part.ie same numbers as are on the original. From memeory some of those are reasonably priced so ask a dealer for a price of a new one.
mechnificent,
Jan 24, 9:28am
Always a good idea to check the wiring and plugs before deciding it is the sensor. Get a wiring diagram, suss which wire or wires come and go from the sensor, and which pins they attach to on the computers plug, then use an ohm meter or use a voltage gauge to check they have continuity at the computer. Inspect all the connector plugs are connected as well.
