Mitsubishi Galant Dash Clock
jancemord, Feb 10, 3:53pm
Hey,
I have a Mitsubishi Galant 1999 with a dodgy dash clock that does not keep the time,Were can I find a replacement!
lazzo, Feb 10, 3:57pm
Common fault on Galants, so if you get one from a wrecked car you could be getting what you've already got!
inkapuka, Feb 10, 3:58pm
Its called a wrist watch
_peas, Feb 10, 4:05pm
http://www.wheelsjamaica.com/wheels_forum/index.php!topic=114884.0 that search took 0.24 seconds. thanks google.
phillip.weston, Feb 10, 5:27pm
easy to fix, just pull it out (takes some wriggling, you need to pry the front of it up and then pull towards you) and disassemble (two screws and a couple clips) and touch up the dry solder joints on the plug socket. Have done to every single 8G Galant that has passed through my hands and takes about 5-10 mins depending how long it takes the soldering iron to warm up!
