06 VZ Commodore (Alloytec) "Powertrain Error"
xxpupxx, Mar 9, 6:17pm
Anyone in the know, know anything about this!
a.woodrow, Mar 9, 6:48pm
Theres a few things that could cause the powertrain light to come on, you need to take it to Holden or an auto sparky to diagnose.
xxpupxx, Mar 9, 7:00pm
Ok thank you :)
franc123, Mar 9, 8:00pm
Its logged a trans or engine fault code, probably best to go to Holden and get it scanned to get an idea of whats gone wrong.
jfstyle, Mar 11, 2:59pm
mostly this is a oxygen sensor fault
himandme2, Mar 11, 5:44pm
I had the same problem with my 06 VZ, they replaced O2 sensor, all good now
a.woodrow, Mar 11, 5:49pm
x1
The oxy sensors are in a position that exposes them to stone damage etc, so a damaged one often brings the powertrain light on, however, there are a lot of other things that can also bring the light on so you should get it checked out asap nevertheless
