got this 3 door toyota echo. for the 2nd time now water has been in the first 3 cylinder spark plug holes. enough water to cover the spark plugs. looks and smells like coolant water but is it even possible on that motor for coolant to run into spark plug holes! its got the separate coils on top of the rocker cover.
ml6989,
Mar 3, 8:24pm
Anything is possible! If it is coolant from the engine then the coolant level should be low. Check it when it is cold, top up if necessary and monitor it daily. If it disappears then you have a problem.
Mar 3, 8:40pm
i think a guy had this on a toyota posted on here cracked head i think it was . try expired listings water in sparkplug as search last year as search on left for motoring
pete_iam,
Mar 3, 9:03pm
thx. must be surely. cant see how rain water is getting in there.
