Brake lights and wof
sleepyheadz, Feb 26, 8:01pm
can a car still pass the wof if one of the brake lights are not working!
n1smo_gtir, Feb 26, 8:06pm
NO! some inspectors will be nice and offer to replace at cost of bulb and pass you. others just plain arseholes. just check all the basics before you take it in. saves the hassle especially with likes of a bulb.
a.woodrow, Feb 26, 8:06pm
Generally no. if it is a high stop that is comprised of multiple LED's then some can be not working but it has to meet a percentage requirement
franc123, Feb 26, 8:18pm
Not their fault you've presented them with a non compliant vehicle that you are asking them to certify is compliant.They're under no obligation to fix anything, there are reasons other than blown bulbs that cause lights not to work.
sw20, Feb 26, 8:35pm
Good business taking those two minutes to replace a bulb. They will come back next time.
twink19, Feb 26, 8:56pm
no dirrerent to the nav lights on a plane or boat not working,
rpvr, Feb 27, 6:10am
"Must have just gone out, it was working when I left home." I'll bet AVIs hear those words on a regular basis.
mrfxit, Feb 27, 7:04am
Have done the pre-wof checks & had it happen on the way TO a wof.
Both brake lights doa.
Another day lost a number plate light & a tail light when checked at home.
WAS found to be a broken earth wire in the tailgate a bit later
johnf_456, Feb 27, 7:22am
It does happen, light bulbs give no warning they are going to blow.
meathead_timaru, Feb 27, 8:58am
Yes. But it depends on which one.
