I use one like the top one, works really well. Just hang it up a bit higher than the brake that you are bleeding. The magnets not that good so I just wrap a bit of wire around it to keep it in place.
kamitchell,
Mar 22, 11:08pm
And I have the bottom one that works ok. only problem with the style I have the brake fluid being hygroscopic the metal ball and spring can (and do) rust. A squirt of CRC or the like helps. Also use a heavy containerto bleed into. All said and done I wouldn't mind trying the top one.
mecanix,
Mar 23, 3:34am
I use a plastic bottle with a piece of vacuum. Hose
scuba,
Mar 23, 4:58am
i've used both the one you have is better.
bill-robinson,
Mar 23, 5:31am
+1 but plastic hose
thunderbolt,
Mar 23, 6:54am
+2 with a mixture of plastic and vac hose in an old brake fluid bottle and its done the job for 20 years
gmphil,
Mar 23, 8:38am
+3 plastic bottle in vacum hose took 2 mins to make
Mar 23, 8:42am
i did have the bottom one the rubber and all has disintigtaed over time , i also have a vaccume compressor one and usually you still want the good old 2 man bleeder for the last bit bleeding .
